Model parts...
67 Power Wagon
Hemi Pawr or BUST!
Hell, USA
Guys,
Those of you looking for special model parts, I have GREAT news! They are coming!!!! I've got molds made, right NOW to include but not limited too:
ALL are 1/24th or 1/25th scales....
Slant 6, 2 different versions! One from MPC with transmission, the other is a block, and head, separate valve cover (I need to mold yet), and the matching 727 Torqueflite transmission....Oil pans, timing chain cover/water pumps for both....I have to get all the parts molded, as fast as I can....
I've also got 440 valve covers (TRUE Mopar designed ones NOT after market) With heads.
Multiple Hemi Valve covers....
Oil pans for both the 440 and the 426 Hemi.
Couple of Small block "LA" motors with Auto trans as well, Parts to it, to follow!
Stay tuned, more to come as far as engine and transmission parts, all high quality Resin, as I will get pictures of!
Prices? Nothing expensive....Trades will be welcomed!
Ideas for future projects:
Really
need some M/T or Edelbrock finned valve covers for both big and small block motors. Also really need modern intake manifolds like an Edelbrock Air Gap for all Mopars. Also really need correctly designed block and timing cover, with distributor in the right place for big blocks & Hemis. None of the model companies have ever gotten them right!
So guys,
Here ya go...
426 DOHC Hemi Head, showing valves, and deep sump oil pan to the same engine!
426 Hemi Valve covers, saying or raised lettering to say "Mopar HEMI" with the penastar in front of "Mopar" The chrome one, is the master copy, mine is well, the resin copy! Included is the head for said valve cover,. THESE are currently in this picture NOT cleaned from "Demolding"
Seen here is the chrome master copy as well as a set (enough for 2 engines) of the Small Block "LA" Mopar engines.....
These are the mold completed in storage parts so far. Seen here is 2 different types of Slant 6 blocks, a single type Small Block "LA" Mopar engine, Assortment of Hemi Heads AND Valve Covers, and oil pans for all of the above! Timing chain covers for the slant 6's also done and being made, I've got a TON yet to make, BUT the parts are coming, it takes a couple days for the molds to cure to be of use AFTER 36 hours....
Of course at this rate, ALL are 1/25th scale...I've got some 1/16th scale plans for engines as well, BUT thats down the road.
Something I want EVERYONE to remember.....I am doing this out of fun and being so, the work takes a bit of time to make/create the master copy, I do have some limitations on making my own molds and pouring them from resin plastic. HOWEVER if I can come up with at least one flat side on any one object, I can mold it, and nothing over 4 inches long by 4 inches wide....The small parts, are done in a cooking sort of way! As you may see in future pictures!
Now as I'm sure all have read of me, I owned one time a Hobby Shop, I'm now enjoying all of those fruits of my labor from the very beginning, when I started....Because I no longer have the "shop" ALL that I owned is at my house, and I do this at home as well....YES, I've got one hell of a mess, if you only knew, but.....ITS FUN or I wouldn't be doing it. SO, as time passes, please, hang in there, things will happen as I am able!
Thanks for the interest everyone! ENJOY!
Really
Let me see what kinda of "interest" I can gather and want parts to make the whole process justifiable for me....The mold making process isn't easy, and its sure not cheap, BUT if you have parts, already, and want MORE of them, send me off a PM on it....IF you have a "master copy" that you like, I can make a mold and with that not charge an arm and a leg for the parts, BUT I have to have some sort of master copy to work from! You supply, ANY ONE of you out there reading this, I'll supply a "set" of that part, for instance, you want a motor, I give you 2, the original "Master copy" you supplied me with, and one copy of it free. You send me a set of valve covers, you get 4, 2 left 2 right, UNLESS its of the straight or inline, (I got PLENTY of Slant 6's done already both factory OEM, and custom models)
Anyone interested, let me know, send me off a PM and I'll see what I can do! It will take an actof og God, himself, for me to just say yes to anything OTHER THAN Mopar tho.....BUT any Mopar company is welcome, past, present, or future!:cheers:
