74 Duster Under hood harness has only one field wire plus main alternator wire.
The is no triangular shaped 2 pin voltage regulator connector on the harness either. It does have 2, 2 wire plugs near the red seatbelt interlock connector.
The car was a basket case when I got it and the engine harness was thrown in the back seat.
Does this sound like a known mod or upgrade?
I'd just as soon bring it all back to use the 2 field wires on the alternator and the standard Mopar regulator.
Not doing the MAD upgrade and will be using the stock ammeter.
Will most likely use hei ignition hidden in an old hollowed out Chrysler ignition box with the ballast resistor modified so it is just a pass thru at full 12 volts.
