[FOR SALE] Mopar 904 SM Blk Street/Strip Trans
dart540
south western PA.
Rating - 66.7%
6   3   0
Fresh Build No RUNS 904 SM Blk Trans A &A RMVB Stock 5- Clutch Drum A&A Spring Pack A&A 1.6 Kevlar Solid KD Band Kevlar Low Rev Band 4.2 Lever HD Band Strut Race Clutches Kolene Steels Billet Low Rev Servo With HD Spring Acc Blocked Wide Frt Servo With HD Red Spring Rollerized Rear Support A&A Modified Output Shaft Low Gear Set Modified Oiling Mods Teflon Rings New Pump Gears Deep Steel Pan with drain plug Pump vent blocked and moved to rear Trans set up for Transbrake if down the Rd you want to update
$2650!+ Core
Add $500 For A&A Transbrake VB
Pittsburgh Pa
Free Shipping USA this weekend
