6valiant9
Active Member
I'm from Central Connecticut, and will post pics upon request. or email
make me some offers!!!
3spd trans with bell housing and shift rods from a 69 valiant slant 6
741 case open, i think 2.73 gears
742 case posi with 3.23, 10 spline pinion
small bolt pattern a-body 8-3/4 axles (pair)
73 dart power steering box
new clutch 4-speed clutch for for 10.5 bell housing from brewers performance.
4-speed shifter mount new from brewers performance
New mopar 4-speed tunnel hump for 67-73 a-bodies
1966 4-speed cast iron case and tail, a-833 transmission, it has new syncros and bearings in it, cleaned up from bearing retainer. 23 input and 26 spline output. i have not painted it yet. new seals and gaskets, purchased parts from brewers.
NRS cast alumini valve covers for LA style heads. (not sure who they are)
spool type engine mounts for small block, new
a set of magnum cast iron heads part ch318a. ported bowls and 1.92 intake valves. ran on fresh engine for 200 miles. they have guide plates and studs for roller rockers (crower 1.6) which can go with the heads.
2 stock flexplates for magnum engines external balance.
thanks
Ross
thanks
Ross
