[SOLD] Mr. Gasket 4 speed shifter
Private Idaho
Dayton,Ohio
Mr. Gasket 4 speed shifter with 8" straight handle. Includes original mounting plate and spacer plate. This was bolted on an A body a833 trans I bought. $65.00 shipped to the lower 48 states.
No. The bracket and spacer are both Mr. Gasket parts. The bracket was mounted to the a833 with two bolts. The part number on the bracket is illegible so I can't confirm it's intended application.
