67Signet
Smoke and chaos stunt coordinator
I have a slant I am hoping to get a lil more performance from it.
Once warmed up seems to idle ok and on the road in first gear seems to do ok 2nd gear ok about mid way but loses power and 3rd never seems to get there,
Almost like the advance isnt working but Ive checked it.
I have not adjusted valves yet but I intend to and Ive located a super six set up as well as electronic ignition but before install I need to know .
(So if you see a better way please let me here from you)
Since I want more performance and I know it will need some parts to get it there I dont want to chase gremlins on a set up I wont use.
I am just looking for more power and I dont want to loose ay gas mileage
please help!
With a stock 160 slant and the three speed I would like to add a 225 slant head but I am not sure if that would be too much flow?
so would I leave it stock or should i mill the head a bit for compression?
and which head do I look for as I`read that the 73 head and up are considered along with the matching cam to be '''factory performance pieces'' plus hardened for unleaded gas. and if true should i mill it and bowl blend and port match as i will not be swapping pistons.
225 head on 160 stock block with super six set up and electronic ignition with a straight 2 and1/4 exhaust with the factory three on the tree and if i can find the correct 3 spd linkage (so I can loose the 3 on the tree).
Also I have the Kelsy Hayes calipers and the rotors so do I just need the bigger ball joints on the LCAs to run them I have the 9 inch drums so I use the 9 inch spindle with the KH set up
thank you for your attention and wisdom in advance!:thumrigh:
please help!
