moparspares
Hi Folks
Here are the parts I have up to now.
Magnum 5.9L Block 30" over studded mains
Probe Forged Reverse Dome 17.5CC dish Pistons
MP 4.0" cast Crank
SIR Rods
Edelbrock RPM Magnum (out of the Box)
M1 Mopar Single Plain
Edelbrock HV Mechanical Fuel Pump
Holley 750 DP HP
Harland Sharp Rollers Standard magnum ratio
Will be going in a Duster with 727 and 8 3/4 3.91 gears
Need advice on Cam, Springs,lifters and Convertor. Have already contacted Comp for Hydraulic Roller and the suggested Custom Grind
.536 Intake 224 Duration
.544 Exhaust 230 Duration
110.0 Lobe seperation
Dont want anything to wild but a good streeter that I can take to track now and again. Would like it to run somewhere in the 11's though.
Also is there anything I myself can do to the heads before putting them on.
What do you think. Any advice greatly appreciated.
MP 4.0" cast Crank
SIR Rods
Holley 750 DP HP
