Back in Time
Now that is what I like to see....
Good looking car! That body style dart is definitely one of the next ones on my list.
I'm just curious, you running bias rear and radial fronts? What's that handle like? Any problems?
Sorry, just read the article which answered many of my questions. Anything you could add? Thanks.
Dom, I have only made 2 passes with the car, just playin' around. No prep, no tuning and I really peddled it out. It still spun through 1st and I had to lift a couple of times in 2nd. It ran a 7.02 @107.
It is a ball to drive on the street. The thing idles about like a stock 426, but it pulls like a freight train from 3,500 to 7,000. Believe it or not, I haven't done any tuning on the carbs, they are OOTB Holley blower 950s. And are fat as he!!. There is a lot of power left in tuning. But I don't intend to do any more tuning than the couple of hours of dyno time we did to set the timing and boost levels and to monitor the detonation point.
I am busy building a 540 Hemi and 518 for the Cuda. When I get it together, I plan to dyno it with the 1050 that is on the 500 wedge that is in the car now. If the 540 needs more carb than the 1050 (I think it will) we'll hook up and build an 1150 or 1250 for it.
I have done this before on some cars. My cars are not corner carvers, they are street and strip so mostly straight line. I have never had any problems running bias on one end and radials on the other.
And I don't normally run that narrow a front tire either. I want some meat up front to counter the much larger meats on the rear should the thing get sideways. But those Continentals are 8 plys which should keep the rim off the pavement in a side skid. Which can happen at the strip. Skinny front tires may be a fraction faster, but I prefer to run a 205 or 215 front tire for control.
I also quit running spools on the street for the same reason. A tight Sure-grip may give up a little bit of 60' time, but won't plow the front straight ahead as bad as a spool if the rear gets out too much.
