My new groud pounder!!!!!
younggun2.0
federal way, wa
Well its been 11 months of waiting. Today i finally got to see the fruits of my labor. Here are the specs!
400 b block
bored .033 over final bore 4.375
molnar forged chromoly crank. 3.910 stroke
scat big block chevy rods. .990 small end 2.2 big end
Icon forged pistons full floating pins. 1.320 compression height -12cc step dish installed at
zero deck. yielding 10.52:1 compression
total bob weight 2274g
main studs and girdle
comp cams solid roller stick. # 23-702-9 xr286r-10
248/254 @ .050
576/582 lift with 1.5 ratio rocker but i will be running 1.6:1 rockers
cam installed at 106*
this will be run with dragster style pan. built in scraper and screen. single swinging pickup and external oil lines with milodon billet oil pump and cover.
top end will be trick flow power port 240 heads flowing 325cfm @ .600
weiand high ram with twin 750 carbs built by bigs
2"-2 1/8" step headers into 5" collector and reduced to 3" duel exhaust dumped at the axle.
this is all going into my 67 dart that has run a best of 11.65 @ 115mph with the current 383.
It's haloween and you are creating a monster. Those 400 stroker are animals.
Had a friend build one for a 69 Road Runner and he had a hard time keeping it straight. Lol what are you putting it in?
Far out.Simular to mine.Cept 11.3 to 1 and E85
.............That's a great recipe......it will run fairly tame.....what size stall converter do u have?.........my 470 is just over 11.-1 with mild port stage 6 heads, 625 comp roller, single 750 carb 655 hp 617 tq .......kim...
boy, we could all have a great race together! mine is almost a mirror image of yours, w/ a little more cam, and more cubes. same dragster pan w/ single swinging p/u, raised port heads flow 352 @.0600. 3500 hughs convertor. what gears and tires are u going to run ? I like that manifold !
Nice hardware,2.0... That combo ,with the newer drag radials,should give some g pulls... The newer drag radial sizes,are crazy good....
I am running a dynamic 4500 stall, 4:10 rear gear with 13x28" Mickey drag radials. I am hoping for 600+ hp and 10.50 ET on pump gas
You ran good numbers with the 383 ..
Good luck with the new build ...
Just gonna drop a follow here... My dart will have a very similar setup: 400bb low deck, .509 purple shaft, indy cast heads, 750 holley, and a reverse valve body 727.
Looks like we are doing about the same build..... I'm running Indy EZ heads that are fully CnC'd and about the same cam (solid roller) hope my carbs are big enough .... can't wait to fire it up ... Dan
1970-dodge-dart.5855
Love to see a pic with the hood closed! I am planning to run velocity stacks with 5" filters. I'm thinking they may be way too tall lol
