Need +4 Tranny Fluid Substitute
What to do to get home
  • Use Type F fluid
  • Use Dextron 3
  • Call a tow truck
  • Call and have +4 delivered
  • Find nearest ice cream place
  • Eat rubarb pie then worry about tranny
Results are only viewable after voting.
Jadaharabi
Peoria, Illinois
15 miles from home and tranny is acting up. It's 2 quarts low on fluid. I don't have any +4 but I have 2 quarts of type F and 2 quarts of dextron 3 what should I do?
Jadaharabi
2 quarts in 10/12 quarts ??? & 15 min from home , add the dexIII & roll :).
Edit,
DEX III history.
Long read, however this Gentleman designed the fluid & the evolution.
My wife used to have a 96 Cirrus that needed AFT+4. I added Dexron to it because I didn't know any better at the time. It screwed up the internal seals of the A604, and it ended up costing me $1200 to get it fixed at the dealership. I'll never mix the 2 again! :BangHead:
AAA is worth every dime. Get the Premier membership. Tell 'em JOS51700 sent you, and they'll charge you double.
