Need a speedo pinion
RealWing
Ontario, Canada
Need some help
My speedo is reading high and I need a different speedo pinion. Looking for a 39 tooth long shaft (Dark Green) pinion. p/n 2538608/52068061. Could not find one when googling. Anyone have a lead? Used is OK.
Thx
Jim
I ended up buying a new one from Classic Industries. However when I went to install it, I fiund that the speedo cable would only go into the end of the shaft by 1/2", as compared to an original one that has the hole drilled 1" deep. Thus It cant be assembled.
I have no idea if all these "new" speedo gears have the same problem - but beware. When I went to check on the used one that was on ebay, it has been sold!!
Now I'm back to square one looking for a good original used one.
