Dusty340mopar
70 Duster
So I installed motor and trans in my duster with a QA1 tubular front end. I used the motor mounts off of the original 318 I pulled out of the car. I modified the plate to the motor where it sat in the mounts with the trans in the bolt up position. The motor seems to be off center, but the headers fit between the torsion bars perfectly. Is this correct or should the motor measure centered between the frame rails?
