Bunker45 Well-Known Member Joined Apr 2, 2013 Messages 214 Reaction score 7 Location Ohio Oct 6, 2015 #1 I have an a body 8 3/4 with axles with long wheel studs. Where can I get new axles with regular stud length? Best place? Thanks
Bad Sport HALF A BUBBLE OFF Staff member Legendary Member Joined Jun 12, 2010 Messages 44,805 Reaction score 34,731 Location The Wolverine State Oct 6, 2015 #2 Why not replace just the studs??
diymirage HP@idle > hondaHP@redline Joined Oct 12, 2012 Messages 34,356 Reaction score 44,076 Location michigan Oct 6, 2015 #3 or trim them down with a cutting wheel
Bunker45 Well-Known Member Joined Apr 2, 2013 Messages 214 Reaction score 7 Location Ohio Oct 7, 2015 #4 I may cut them, didn't know they were replaceable. Good ideas!!!
Bad Sport HALF A BUBBLE OFF Staff member Legendary Member Joined Jun 12, 2010 Messages 44,805 Reaction score 34,731 Location The Wolverine State Oct 7, 2015 #5 Bunker45 said: I may cut them, didn't know they were replaceable. Good ideas!!! Click to expand... Yes, they can be pressed out and replaced. IF you cut them make sure you have a nut on there before you cut so you can thread it off and clean up the threads. The easiest would be to cut them I suppose. Dress up the end a bit and then remove the nut, it should thread right back on that way. Measure, measure and measure. That way you don't cut them too short.
d5667 Member this? Joined Oct 21, 2009 Messages 11,908 Reaction score 5,906 Location Mo Oct 7, 2015 #6 Or thumped out with a two pound hammer and pulled through with nuts.
