JamesRR
I have a 1971 Dart with a big block stroker in it. Had it at the shop for a top end noise and when it was hoisted on the lift we saw that the pitman arm and idler arm are hitting the headers in a bad way. the lower control arm is also rubbing a bit on my milodon oil pan. The headers are TTI. Are there pitman and idler arms that are longer/lower to avoid rubbing anything or is my motor sitting too low? Any help appreciated as car is in the shop. Thanks so much.
Best,
James
Best,
James
