MrDuster
Hi folks. I took this piece out of my 71 340 Duster this morning. What does the silver cylinder with a single electrical bullet connector do? You can see where in the past the exhaust burned the speedo cable and the guys plastic-tied/siliconed it
last time I drove it I notice the needle was fluctuating with noise--as I'm putting the rebuilt tranny in soon I decided to replace the cable. When I took the plastic piece off the speedometer I broke it due to my gorilla touch
.the bottom line ran under brake lines with close tolerance to the body
.as the cable was going to be replaced anyway I cut it to make it come out easier. Should/can I buy an upper and lower cable and go back through the silver canister or just buy a new cable
.any suggestion on where to buy the cable? Open to any/all suggestions as I have zero experience with this. Thanks!! Mark
