AJ/FormS
68 Formua-S fastback clone 367/A833/GVod/3.55s
- Joined
- Jan 19, 2014
- Messages
- 25,057
- Reaction score
- 12,400
Only Brian can answer that,lolWhat book are you referring to
Oh gee whiz forget about that pattern, the rotor is constantly moving about under there from about 1000 to 3000 or even a little higher depending on when it starts it's march and at what rpm it finishes. That is normal. If it hits the right tower that is all that is important.Other than sometimes kicking back, I noticed when I had the cap off I looked at where the rotor had been firing on the towers. It is only firing on about three quarters of the towers on each cylinder. You can tell by the marks left on the towers. I cut a large hole in the side of the cap so I could actually see the rotor when it is firing with my timing light. It looks like it is firing just like the marks that was left. My initial shows 22 btdc. It is like the rotor needs to be turned about 7 degrees to fire on all the tower surface
Knowing that I would say too much initial. One of the other guys mentioned a switch. I have a buddy that used to run a Small block Corvette in Division 5 NHRA. He had the ignition power wired through a toggle switch. They would spin the starter then light the fire with the switch. I don't know how much initial they were running but it was too much for the starter. Worse when the engine was hot.The vac is disconnected and the mechanical doesn't start till 1200 rpm checking initial around 900 rpm with light
You have a book that lists a spec for a 416/.570lift solid roller? lol
Well said AJ!Here is an experiment;
Turn your crank to 22* BTDC compression #1cylinder.(Your chosen, perhaps arbitrarily, initial timing)
Pull the cap off and get it out of the way.
Take the coil wire out of the cap and near-ground it.
Loosen the the Distributor. Just so you can turn it a wee bit.
Eyeball the relationship of the magnetic pick-up to the reluctor. They should be sorta directly across from each other.
Turn the key to RUN.
Push the v-can several degrees towards the firewall. Then slowly pull it back towards the rad while simultaneously watching and listening for the spark event to occur at the near-grounded coil wire. SNAP! there it is! Stop pulling and eyeball the relationship again. It should appear much the same as when you first saw it. Repeat this several times. If the snap does not occur, rotate the distributor slightly faster, some pick-ups are lazy.
Notice the coil wire did not care where the rotor was.
Turn the key off
Go back to the crank and rotate it to set the timing marks to 16*BTDC.
Go back to the Dist and push the V-can back several degrees.
Turn the key to RUN again
Return to the Vcan and give it a light smooth tug until the snap occurs, Repeat several times. and lock the D down.
Again the rotor was out of the equation.
Now grab a sharpie and mark the position of the rotor tip on the outside of the D next to where the cap will sit
Grab the rotor and give it a little twist to see which way the rotor turns and how far.This distance has to be compensated for in the positioning of the #1 tower. Make a corresponding mark next to the first mark where the rotor tip will eventually be as the rpm goes up.
The number 1 tower will have to be the nearest tower to those marks while the engine is running. Grab the cap and make a mark where the cap sets on the D body, at the #1 tower location.
Now set the cap back on the D, and observe the two sharpie marks you made on the D. Ideally they will be straddling the #1 tower mark. But they don't have to be. As long as the rotor is always closer to the #1 tower than to any other then it will spark correctly.
But if this experiment shows that at some rpm, the rotor will be closer to an adjacent tower, than to the #1 tower, THAT HAS TO BE FIXED.
Now put it all back together and fire it up. Set the idle timing to 16*.
Rev it up as high as it takes to make the advance marks stop moving. Record the number, and the rpm. If it is less than 36* go for a ride.If more than 36* don't floor it. If it is more than 37* or less than 34* then we are gonna have to modify the dizzy, OOps D!
But first, see how it likes 16*. Take it for a ride and warm it up good. Come home. Shut it off,and immediately attempt a restart. If it fires right up without kickback, Shut it off and wait 10 minutes and try it again. If it is still alright,make a note somewhere in your notebook that 16* was alright.
Then the tune begins.
Thank you brother. EDIT on the JB weld I do not glue the plastic per se but after I widen the notch in the upper dist metal shaft I use it on the opposite side to restore the notch width to its original dimention so the rotor "land" will fit snugly down into it. its alot of filing so I started drilling a new roll pin hole in the reluctor. I drill the hole aways in from the ID then file it outward till it breaks free to the ID with a mini rat tail file. careful measureing required but there is alot of room to repeat.Rapid Robert has it right. congrats
the internet does have a few downsides but the perks are very well worth it. You tube is the best goldmine I have discovered so far. I had a coolant leak that was eluding me (wouldn't hold psi even before fireup so no coolant to spot) & guy on there on a video said to put a rag in a 1 gallon paint can with some baby oil & set it on fire! & plumb that into the cooling system & with its own built up psi you will spot the leak & wah la I found it right away & a shop want $45 hr to hookup their smoke machine to it & the car was not race ready & would have to have been towed or the eng pulled. EDIT the best thing I like about FABO is when someone posts a problem multiple people (as in dozens) will contribute toward the solution! just takes time (not a problem when you are retired).simple things they take way to far. misunderstood
only vac adv will change the rotor phasing position, not RPM so while idling if you plug the can into manifold vacuum you can check RP with a 1/2" hole in the top flat of the cap 2/3 of the way between the center dist cap terminal and the #1 dist cap terminal & the rotor will swing to the most CCW clocking position (on a SB).
Took me a sec without coffee, but yeah. The reluctor and rotor are on the distributor shaft with the mechanical advance. The magnetic pick up is on the breaker plate that the vac advance pulls on.Let me get this straight vac advance can will affect (change) rotor phasing But. mechanical advance (rpm) will not???????
