downsr
Getting ready to adjust cold lash on valves .Cam card says .020 hot lash on both intake and exhaust. What should the cold lash be ? Camshaft maker says .016. The engine is a 340 block
with elderbrock heads. I was told previously that you should allow .006 with aluminum heads which would make the cold lash .014. Whats some of your guys opinion on the cold lash setting
It is a solid lift roller camshaft
