neon wheels
mopar_nocar
Center Point, TX
anyone out there use neon (or similar) wheels on the older 4" pattern. i did the conversion from metric and a 5x100 is 3.94"....purdy close to the 4" pattern. i guess with spacers you could run the 15x6s off the neons, right?
let me know if i am way off on this one.
sb
I tried some Daytona wheels once. I could get them on the studs but either the aluminum of the whhel would be displaced or the studs would bend tightening the lug nuts. Also the center hole on the Daytona whhesl was smaller than the hub on my Barracuda.
shoot. i found a guy who claims to have run old style 4" rallyes on his gen I neon. maybe i can get a hold of him and see what's what.
sb
well if its tight using a Daytona/neon wheel on a A body that would make the A body rim loose on the Neon.
