POPS6T6
So after doing some research I have learned more than I ever expected about the switches and the "rooster-comb" lever...but I am still wondering what switch I should use. I have a 1966 Barracuda, putting the 360 and 727 in hopefully this weekend (finally). On the transmission it has a single prong switch, but after looking up the #'s on the case PK4329468 8536 8671 I figured that this should be an 84-85 transmission (someone please correct me if I am wrong) and from what I learned the 69 and newer transmissions use the 3 pin neutral safety and back up light switch. What is odd is that there is a single pin switch in this transmission? Now it was rebuilt and so I am wondering if someone just put the wrong switch in it? Based on those #'s, shouldn't I be using a 3 prong switch so that I will have backup lights? Also since the car is a 66, would it have the correct plug or would I need to change it out and rewire it for backup lights?
Thanks,
John
Thanks,
John
