New 1920 carb replacement? Who wants to be the first to try one?
pishta
I know I'm right....
Tustin, CA
Mao's version of a Holley 1904-1920 1bbl. Who's gonna try one? $89 shipped for a NEW casting...May not be that bad, I've had good results with Chinese carbs
1 Barrel Carburetor REPL HOLLEY 1904 1908 1909 1920 Fit For Ford 6CYL Engine | eBay
If you are stuck on a stock replacement, I’d say it’s better than a parts store rebuild. As with all discount Chinese parts, I would open it up, clean out any debris/casting flash and run a quality gasket set. Check the float and you are good to go.
I plan on getting one for my Falcon whenever we have a little extra dough.
I can hardly believe it, but I have had good luck with the 2bbl $85 special 2bbl on my super six powered car.. If this 1bbl is built in the same way, I'd give it a shot.. If my 1-bbl powered '67 valiant has issues running, I'll give this one a try..
Interesting that they copy the Holley 1920 design almost exactly, though perhaps carburetor design hasn't changed much in 50 years. Actually, in motorcycles where some are still used (or were until recently like Ninja 250 for U.S. market), they have a variable throat area ("slide") which is what I recall was the automotive Predator carburetor's claim to fame, and also enrichment during rapid deceleration to avoid pops. I don't see a bowl vent, which I had on my 1969 Holley 1920. I think later ones plumbed the vent to a charcoal canister. It appears to have a sight glass to verify the fuel level, which is great. In the past, you had to remove the "economizer" (3 screw thingie on top) to measure the fuel level. That part actually enriches the mixture under certain conditions, which I think makes it equivalent to the "power valve" in 4 bbl Holleys.
I have one of those 2bbl $85 specials on my 318 and it runs well except for a little whistling noise occasionally and the throttle response isn't as good as the Carter carb I had before it. I wonder when they'll start cloning the Edelbrock 4 bbl. Lol
They didn't, actually. That same basic style of Holley 1-barrel carburetor, with the rectangular float bowl facing front and the float hung from the starboard side, dates back to way before the 1920 came along in 1962. It was in use in the 1904 (the glass-bowl "Visi-Flo" carburetors of the '50s) and others. Numerous models and variants built not only by the Holley mothership in America, but also by subsidiaries and licence holders scattered all over the world. There are quite a few pretty fundamental differences between the current-production Argentinian carb and the 1920—the separate throttle body is more 1904like, for example; the airhorn configuration is different, there's that screwy (zing!) adjustable jet, etc.
Long-long before the Predator existed, variable-venturi carburetors were commercialised in huge numbers by the likes of SU and Zenith with great success, and by Ford with miserable failure.
It looks like the bowl might be vented via that small transverse hole in the casting, just aft of the the top bowl screw. There also might be an internal bowl vent we can't see from this angle, but without the angled draught tube we're used to seeing on the American 1920 (and most other carbs—it's there for a good reason, too, which would make its absence problematic).
No sight glass; that boss you're seeing on the float bowl is for an externally-adjustable jet. Conceptually that strikes me as roughly 50/50 benefit/drawback, but I have no practical experience with this implementation of it.
You still have to do that on this Argentinian carb.
"Economizer" was just Holley's cutesy name for the power valve on the 1920 carburetor.
