how does the roller tip land on the valve tip? that angle looks like mine do and my engine see's 7k on a regular basis.
http://s370.photobucket.com/user/johnnydart_photo/media/download.jpg.html
The rollers are just to the intake side of the center of the valve tip, so they should traverse across the centerline as the rocker cycles, correct ?
Did the heads get the valve job and guide clearances checked before they were bolted on?
Hey red - need about two to three threads coming out the adjusters, should look like youngguns. Angle looks a little off, but can be camera and such.
Need the group to check my pushrod setup.... Does this angle look acceptable, with a checking length of 8-7/16 inches ?? Also, do I need 5/16 or 3/8 pushrods ?
I'm getting in on this a little late, but this two to three turns on the PRW rocker arms may be extremely poor advice.
The oil hole in the rocker body lines up with the adjuster hole in the PRW rocker screw when you back the screw all the way into the body until it stops and then you turn it out ONE TURN. Three turns out may block the oil hole completely off. Unless you have actually tested the PRW rockers, generic advice on rocker screw threads exposed may not be wise.
That looks super nice! Yall oughtta be proud of it. I know I sure would be.
is this the first engine you have built? you are doing a damn good job
Picked up the 727 trans and converter from JW Transmission on Monday. Here's the trans with the cable kickdown brackets installed. Will probably try to pull the old 318 out of the Dart over the weekend......
what stall speed is your converter going to be? what about rear gears? if its your sons first build like this i might be inclined to put a open diff. in the rear till he gets used to it.
