jameskernz
duster Man
I took rebuilt the bottom end of the 340, low oil pressure problem,, went from 15 psi at idle to 60 psi,, Along with that took the 484 purple cam out and replaced it with a Howards Cams 470/275, 108/104, 221*@50 duration. Also replaced the single plane intake with a dual plane air gap. Car runs great. Idles perfect and a joy to drive. Miss the idle chop though. Power on the bottom end is noticeably better.
