Different clusters are "different" but here's what all was wrong on my 67
First, the cluster PC board connectors were bad, loose, broken. mIne were so bad I abandonde them and bought "Molex" style connectors a Radio Shack, and soldered pigtails to the board traces.
Second, buy yourself a good quality aftermarket, solid state instrument VR.
Next, inspect the board carefully, or consider getting a repop On mine (non rally) the VR contact fingers in the board were NOT making contact with the board traces, and I had to solder jumpers between the contact fingers and the board.
The fake nuts on the gauge studs were not making contact with the board. Replaced them with real nuts, and loosen/ tighten/ loosen/ tighten them to scrub things clean.
The sender wiring may have troubles. The temp sender goes though the bulkhead connector, always a suspect
The tank sender may not be properly grounded.
The sender end connectors may be broken/ corroded inside the rubber molded ends.
Once you get good solid 12 to the board (fixed the harness connector / board pins)
Once you fix the VR connector and get a good VR
Once you fix the gauge stud connections.
THEN you can use resistances to check the accuracy in substitute for the senders. Temp, fuel, and oil (rally if used) are all the same.
If you go to Radio Shack, and buy 4 100 ohm 1/2 watt resistors, and wire all 4 in parallel, that should give you very close to 1/2 scale gauge reading. Allow sufficient time for the gauge to stabilize
The test resistors are:
L = 73.7 Ohms (empty)
M = 23.0 Ohms (1/2)
H = 10.2 Ohms (full)
