highflyer
I PUT A NEW STANDARD [NAPA ]SWITCH IN A YEAR OR SO AGO.....I went over to pick up some brake cleaner at the store yesterday and came back out and the car duster would turn over but not catch..checked squirters ,had fuel..after a couple cranks it still wouldn't but it tyred to run when I 22went to turn off finally after this it started and I got home..put a light between wire and plug and cranked motor..no light in window..then lite showed and it fired off..did it again no lite..after a few seconds of cranking no lite soon as the lite showed up it fired..went to put it in the garage it lit off but couldn't stop the starter from engaging..no spring tension and couldnot stop starter...I guess its safe to say the standard ing switch is toast...SO after a long story a short question..who ,what company is now making the best switch for a column mount[73 duster] switch.also,iv had motor missing probs since new and lights flickering.maybe questionable switch????.tx,,j
