new to turbocharging
walt68
Member
wylie tx
How thick headers flanges to use, if you making your own headers.
I welcome any advice.
Thanks Walt
I used 3/8" but 1/2" would be better. Be sure to use studs instead of bolts!
1/4" flanges will work.
3/8" flanges are better.
1/2" is Best..
the The Material the flanges are made of is more important.
Mild Steel...ok.
T304....better.
T321....best.
I recommend the TiG process for welding TURBO HEADERS, but you can stick pipe together with a coat hanger and a torch if you want....but I dont recommend it.
mine are 3/8 t321 stainless as are the tubes. ive never had a leak, i dont use gaskets, ive got about 4000 miles on my kit.
