LXguy
OK, anyone ever sprayed 100 shot on a stock 318 shortblock?
Its in a 72 Satellite if that means anything.
Thanks!
Steve
Thanks!
Steve
That will get you up to about 220HP. You could probably hit it with a 250 shot.
How many times did you spray it with 275?GO for it. I did a stock 318 with 275 before. It didn't break it. Keep the timing back and make sure there's enough fuel pressure with the solenoid open (free flow test).
The same guy that struggles with driveability issues and tuning probably shouldn't be just bolting on nitrous. Especially bigger hits as "your results my vary"...lol.
I'm sure it been discuss before but what all would I need to put a 100 shot to my 360 would a stock file pump work ? Also what about stock distributor
Pull the timing back to 34 total. 2 degress for every 50 hp NO2
rich too.and if you have a tight quench some more, Timing is what kills N02 motors not "Lean"
It wasn't. Just a general statement.??? If this is directed at me I have no idea what you're talking about.
