dkbug
Not getting fire and I can not figure out why. Before I decided to add the electronic ignition, I could not get my points system to work either. I figure on the points system that my distributor was not any good, resulting in me buying the electronic ignition kit from summit.
I was not sure about everything you guys needed to know so I got as much as I could.
Let me know what you guys think because I am at a dead end.
Units: Volts (v)
Battery: 12.19v
Ballast resistor
Ignition switch side: 11.32v
Ignition control side: 10.81v
Ignition Switch
Red Wire: 11.88v
Blue Wire: 11.80v
Brown Wire: 11.26v
Black Wire: 11.85v
Yellow Wire: 9.8v (When turning the motor over)
Distributor wires
Black/Yellow? - 0v
Brown/white - .11V
Units: Volts (v)
Battery: 12.19v
Ballast resistor
Ignition Switch
Red Wire: 11.88v
Blue Wire: 11.80v
Brown Wire: 11.26v
Black Wire: 11.85v
Distributor wires
Black/Yellow? - 0v
Brown/white - .11V
