installed alum heads buttoned up my 360 no oil psi,, had plenty psi before change,, went through the norms for no oil psi, used a short oil filter this time filled it first zero,,here's what I'm thinking when installing headers i used the oil pan to lift motor,a block of wood and tranny jack so there was even pressure across pan,, I didn't notice any major dents in pan after I finished could this have caused no psi,, gonna remove pan Tuesday what else should I look for
