SwingerSteve
Thanks a lot for your help,, very appreciated from all of you guys.you have the correct coil...put a volt meter on the + side of coil and see if you are getting 12 volts...i see your ballast resistor is wire....but do those wires go to the coil?.....there should be no resistor in the circuit...if you do not have 12 volts at coil...connect the two wires on the ballast resistor ....then check coil again...
the ballast resistor is dropping the voltage to the coil for the mopar system....you dont want that with that distributor and coil
