The tire has a certain roll-out; that is when installed on the vehicle, and you roll the car out for one exact complete DRIVE-tire revolution, you will get a number. That number then goes into the formula and it spits out a number. If your tach or speedo does does not agree, then one of three things is happening; The tach is wrong, the speedo is wrong, or the TC is slipping.
A 24.5"tire has a rollout of 77 inches. The formula says
(MPHx1056xrear gear)/tire roll out= rpm and in your case this is 2840 rpm. That would be zero slip.
I usually see less rpm than the zero slip while PartThrottle cruising at say 55MPH. But as the speed goes up and the engine has to work against the wind, then the slip begins to climb.It can't go too far tho cuz the TC will reach a point where slip is maxed out, usually around 5%.
At your statement of 75=3000, you are already at 3000/2840=plus5.67% slip. This sounds excessive to me. If you were at full power, I could see it, but at PT, it sounds excessive to me.
I would question the instruments.
