340wedge1971
I had a 72 904 non-lockup trans,switched to a 78 904 lockup trans.I had to purchase a different torque converter and all the linkage seemed to switch over exept the speedo cable is a screw on type,the old trans had a different setup.Will the flex plate from the non-lockup work with the lockup trans?And,is there anything else that must be swiched to make this trans work?It is going in a 73 dart swinger 318.Thanks....
