I installed a whole new original style KH disc brake set up with power booster in my 1970 Dart - all new lines, calipers, wheel cylinders, hoses, brake hardware in the back, pads shoes, etc. When I turn the key on ('run') the Brake System light on the dash comes on and it stays on when I push the brake pedal. When I start the car, the light remains on until I step on the brakes, when it goes off. The brakes seem to work fine. When I hit the brakes with the car running and the light goes off, I can pull the emergency brake on and the light comes back on, as expected. I have 2 other 1970 Darts and the light only comes on when I pull the emergency brake on (and hopefully if half the system fails, but it never has). The "proportioning" valve ( distribution block) where the wire for the brake failure plugs on is new, as is the M&H wiring throughout the car.
Any ideas what might cause this?
