The way to test it, is to start the engine and slowly slide the dip stick in. It you feel the crank hitting the stick pull it back out and carefully bend the tube to a different angle and try again. Sometimes it just takes a slight tweak, other times it can take quite a bend to get it where the crank won't hit the stick.
