340wedge1971
rebuilt 318,started motor,oil coming from filter plate,should there be a gasket in there?Not using oil filter adapter,just stock filter set-up...
There should be a smaller round gasket as well that fits around the piece that threads into the block. Smaller gasket goes on block side of the oil filter adapter plate. All the kits ive ordered had both.Well,i think i found the answer to my own question...this is the set-up i have,i see that there is a gasket thats supposed to be there...
Good idea to add four more holes to that oil filter plate too.
