oil gauge
spl440
Everybody's Fool
Hot Springs AR
Will be doing the Sunpro volt gauge conversion on my 67 Dart stock cluster , looking into a way to add a oil gauge to replace the oil light. will just adding a temp movement and scale, with using a oil pressure sender be enough, or will the voltage reducer not handle the increased load? Have an extra stock cluster to use as parts.
I installed the Sunpro 3 gauge set, volts, oil pressure, and water temp. I removed the OEM sender from the oil filter mount, screwd in a bushing and used the compression fitting and hose that came with the kit. Not ideal but it works fine.
I only use electric oil gauges, Had a line blow off the back of a gauge once on the highway, not a good thing.
