gdizzle
Ok so changed bulb, which was MIA, in the Oil Light. Now when I put key in, oil light goes on, and never turns off. Even with engine running. is there some sort of sending unit for that?
The light is on for a reason. The oil sender is bad. You confirmed it yourself. When you replace it with a good one, you will confirm your oil pressure by the light going out when the engine is running.
