zac_F71
I'm getting my motor (71 383) done here and looking for the O rings for the oil pump - I bought 2 Mancini plate/ cover gaskets - one came with a small O ring - which I assume is for the cover/ filter adapter.
where can one get the O ring that goes inside the block?
I see Felpro makes the large cover O ring for $.97- I just don't want to spend $37 on a milodon oil pump rebuild kit when mine is very clean and only needs the O rings..
