Hey guys i heard stock lifters wont get oil to the w2/w5 heads, what lifters and push rods are needed to get oil to these heads on a 360, thanks for any info:glasses7:
you are correct cause most of the w2/w5 oil thru the heads into the shafts and then to the rockers
the newer w2 heads that require T&D rockers oil thru the pushrod/lifters...if that is the case...order lifter and pushrods that provide oiling to the rockers..
