Steve welder
New thread dont ask me why, im F-ing disgusted,,,,I never ever had a car give me the problems this one does, like its possessed...
Latest issue
I removed the rockers, blanked off the carb at manifold and put 5 psi air into a the intake....Wont build up pressure, as fast as air goes in it comes out....raised the pressure and I hear a bad leak..... Air is coming out of every cylinder spark plug hole on the even side, nothing on odd side
Compression on odd side is 185 in one cylinder and 190 in the rest
Compression on even side is low of 173 to 180
I put shop air 120 psi into #7 cylinder......No noise at tailpipe.....Air is leaking into the intake manifold and I feel air coming out of #5
At this point I dont think its a head gasket, I think the head is cracked
No pressure buildup in radiator and no water in oil
I dont know what to think
Any thoughts?
Latest issue
Any thoughts?
