Caberocks
Thanks everyone for all the info. I'm gonna get it prepped and re-vinyled. It would have cost a mint to get the top prepped for paint, plus I figure the car was born that way.
This is what I was going to say. The factory also hid a lot of poor panel finishing with those vinyl tops. Like where the roof line meets the quarter panel.Be prepared to do major body work when you remove the vinyl most roofs from factory are not finished under vinyl usually about a 36 grit finish for better adhesion of vinyl top. You will have lots of finish sanding and blocking to prepare that roof for paint. Its not pretty under there from the factory.
The factory did not paint the roof of vinyl top cars. In addition, the holes drilled for the trim, and the installation of the clipd on the rivets all had the chance to cut through the paint. Hence the rust. If you want to "prep it properly" you should just prep and paint the roof. you don;t have to worry about making it perfect, just get material everywhere. Then install the new top. Personally I like them, and if a car had it, I'd put it back that way.
