[FOR SALE] P.S gear box & trw pump
Mysons68dart
So.cal
Both units were removed my sons 68 dart when It was put on Jack's in 2016 the steering gear was rebuilt in 2015 as you can see by the scribe writing on the input shaft housing Buy a reputable rebuilder here in Los Angeles. Not sure about the pump except that it has no leaks. the steering gear has about 2000 miles on it no leaks And worked really good. I Will Sell these Separate. the pump has the slant 6 bracket still on it If you need it.
Steering gear--- $200 Plus the ride And the weight is 35.2 pounds it cannot be put in a flat rate Box so you can calculate the shipping
Pump---- $50 Plus the ride in a flat rate Box.
shipping from 90650
PM me with any questions Thanks FABO
Gary
Im interested in your steering box.
Give me an hour or so and ill conatact you. Im on the road. thank you
