well, there is no 190/70/14 , I would assume you mean 195. you don't say how wide your rim is , there are more than one stock size steel wheel. I would assume its a 14" which are either a 5 or 5.5 width. either way , a 75 or 80 series are the narrowest all the way to a 50 series being the widest.
with a 14 x 5 or 5.5 rim , I would suggest a 60 series tire
One of my tire companies has data charts for recommended tire/wheel combo's...the wider tires will fit narrow rims but perform/wear optimum with appropriate sizing.
Specs/Size
Description
Features/Benefits
Fitments
SIZE P245/60R14
UTQGL 400 A B
SERVICE 98S
MIN RIM WIDTH 7.0000
MAX RIM WIDTH 8.5000
OUTER DIAMETER 25.6
SINGLE MAX LOAD LBS 1675@35
DUAL MAX LOAD LBS NA
RPM 813@45
TREAD DEPTH 11.00
SHIP WEIGHT 29.000
SPECIAL NOTES
if you want a wider foot print better off goin to 15 inch wheels out back and doin a 255-60-15 depending on the car these are goin on.
Cause biggest 14 inch tire is 245-60-14
