340Duster247
I got my 408 together and once the engine is heated up good and been run for while the engine shakes bad at idle. I've been chasing this problem for a while and noticed when I pull the pcv and plug it, the engine smoothness right out.
It only shakes when the engine seems to be producing blow by or when my temp gets above 190. It's like the engine does not like to breath back in those crank case vapours
My AFR at idle is around 13.5-14.5. Timing at 34 total
Is there anything I can do to eliminate this?
Holley 750 dp
Eddy headed
Eddy airgap
Lunati 60405
Scat flat top stroker
Holley 750 dp
Eddy headed
Eddy airgap
Lunati 60405
