Yep, it'll bolt right on. As said above, the Performer is a small port intake. The Performer RPM would be more appropriate. Small port intake, big port heads is not nearly as bad as the opposite combo, but you will still be giving up some potential. The Performer will support 300 HP or so, and below that point you probably wouldn't notice a difference. If I had a Performer laying around, I'd bolt it on in a heartbeat. But if I was ordering a new intake, I'd chose the RPM.
