Pictures of exhaust out the back after minitub
duster360
Alabama
I need some pictures of how the exhaust was routed out the rear of the car after a minitub was done. My car is a 67 Dart.
Check out my photo garage as I have pictures of my 71' Dart with a mini tub using a pre-made exhaust kit from Jeg's with a few minor modifications it can be done.
Thanks for the pictures. I didn't see any where it showed how the pipes were routed and hung at the rear of the car around the spring area.
I used the A-Body flat wade exhaust tips with the welded on hanger tab, along with a Cuda muffler mounting bracket. The Jeg's exhaust kit is split over the top of the axle so you position it to run outside of the leaf springs. I used Jeg's Flowmaster style mufflers and hung them from the stock location behind the rear seat area. The Jeg's kit is designed for use with long tube headers, but in my case I have TTi shorty headers with their extension pipes from there I added a Flowmaster H-Pipe kit. From the Jegs kit the pipe that was meant to run up to the headers was cut up and used make the mufflers fit right. Adding more photos here hope they help you out.
I have the same Jegs exhaust kit with the same tips. This is exactly what I needed to see. Cuda mounting bracket and I am set. Thanks for the detailed info.
