pettybludart
I need to know the pinion offset for the A-body 8 3/4 rearend?Can anybody help with this.Thanks
P.S I,m having a c-body rear shortened.
Thanks Rob,I was hoping you,d chime in with your know-how.Thanks again!:cheers:Cut the rear so it's same axle tube lengths from centerline.
Note - axles are the same length for all 8.75 rears for specific cars/bodies.
http://www.moparts.org/Tech/Archive/axle/16.html
The pumpkin takes care of the pinion offset, not the housing with an 8.75" rear.
Isn,t the yoke off to oneside on the centersection?Or is that just Ferds?
So are you telling me it,s 1 7/8 off?Sorry I,m confused by your answer.ThanksTell him to imagine that the yoke is centered, 1 7/8" more toward the center, then measure for everything.
