Her1970
I changed the pinion seal on the 8 3/4. What is the torque spec on the nut?
You've got those numbers backwards. 489 is 170 to 210 ft lbs with crush sleeve and the 741 and 742 are 240+. Must be a misprint in your manual. Not at all uncommon if the manual is original.170 ft lbs to 240 ft lbs depending on which carrier you have. 741, 742 are 170 and the 489 is 240. That's right out of the Chrysler factory repair manual.
