Oklacarcollecto
Life is an experiment
Do you have a self service salvage yard in your area that would have 76 back cars?
with the wheels straight is the pitman arm going straight back or at an angle?It should be straight back.If its not than the tierods need to be readjusted.Make sure the steering box mount isn't bend upward.Check both sides of the k frame and make sure they are the same from the ground and not twisted.For some reason the pitman/steering box unit is too high.I'm thinking 1" at the end of the pitman.the steering box mounting face maybe twisted where the bottom is rotated upward also.No one knows if the lower(forgot the name)arm the torsion bar is connected to is right for that car or if the bushing for it is good if its wore the torsion bar will be higher than normal but that wouldn't account for the headers hitting.
Thats what I was going to say but didn't want to cause any confussion if it wasn't it.(forgot the name) control?
yeah I'm only old in body and my mind is leading the way.:cheers:LOL, you made me think for a while if I had it correct. I think it is, isn't it?? Getting old is BLEEP!
73-76 Linkage
In 73, A-body front suspension was upgraded in a few ways. The bigger b-body balljoints were now employed. A heavier spindle now used b-body sized bearings as well. The pitman and idler arms were also changed to enter the centerlink from the top. The pitman arm is the same as the 73-up b-body item.
Note that the pitman and idler pictured are fast ratio items. These were simply longer than the standard parts, and otherwise equal. Notice the top-down mounting of the idler and pitman and the now vertical mounting of the inner tie rod ends.
Pictures can be seen at http://www.bigblockdart.com/techpages/linkage.shtml
Bill;
Do you have any knowledge of these longer fast ratio items?
~Michael
73-76 Linkage
Bill;
~Michael
Are you using all 73 and up parts? 72-down had different drag links, pitman arm, idler arm and tie rods. Put any 72 and down parts in the mix and you've got problems. Also, is the tie rod installed upside down?
Dosent ABODYJOE have a link to a 72 service manual on a web site? wonder if that would help anybody
I believe he has it here on FABO. Trouble is the car is a 1973 and has the 73 up spool K-frame. We need a 1973 up manual.
I was thinking maybe it would help eliminate some of the "other" parts.
I think you guys are all kind right. Looks like its a combo of a couple of issues, wore out bushings, miss matched parts per year and some bent parts. If it were me and I had the time, Id take it all apart,clean it and start over.
I think I would find a fully loaded V8 K-frame from a 1973 or newer A-body and go with it to build. Best thing would be buy an unmolesred 4 door donor car if he could find one for the right price.
I tightened up the power steering mouting bolts lastnight..took it down the road about a mile and a half and they were already loose again and the steering box was moving all over...something is deffinatley messed up with this car but i just cant figure it out. I know a new steering box is not going to fix my problem..
I think I would find a fully loaded V8 K-frame from a 1973 or newer A-body and go with it to build. Best thing would be buy an unmolesred 4 door donor car if he could find one for the right price. I would think in MN there would be some A-body grocrey getters with rust issues.
Have someone post pictures of their 1973 up tie rod ends to compare to yours.
I wouldn't just go by pictures. You need measurements. The "look" of these tie rods will very per brand/manuf. And the way the boot hangs over the end will make it look taller or shorter.
This is a 73-76 A-body K-frame. The tie rods are 11/16" C-body tie rods.
The tie rods aren't the issue. There is something else. Start with that steering box that is falling off that car and keep working from there. Figure out whats wrong rather than throwing parts at it.
