Mike Z
1972 Plymouth Duster 340. #'s Match 340 with 727 Torque Flite. I have owned this since 1992 and fully restored her with the best of everything. I have all documentation and pics with broad cast sheet, dyno sheet to prove everything about the Duster. Engine redone and slightly modified .030 over forged pistons with bigger cam, roller rockers, larger valves, some head porting and single plane intake with Hooker Super Comp. headers. Exhaust 3 in to bumper with factory tips. Trans has some mods including 3400 cheetah convertor and a cheetah foreward pattern manual valve body. The duster has a 391 gear with Sure Grip Posi. The frame has welded frame ties. Undercarriage is Solid, Carpet is new with new dash pad. High back factory original bucket seats in great condition. and center console With floor shift not at all modified. Auto meter Gauges and shift lite. Hood is not original but fit is awesome and done correctly with correct hood hinges still used with the correct springs for light weight hood. Msd ignition but also the factory harness and components are there and functional if needed. Centerline drag wheels with new ft. tires and good rear 11 in. slicks. Car is repainted to factory ralley red. Duster has replacement decals that it had originaly. Has manual steering and brakes. All new stainless steel brake lines and 3/8 Stainless Fuel line. All brake Hoses are brand new. Rear springs new with bushings. Front suspension is all fresh including all ball joints and all bushings. New ft. brake shoes, hardware and wheel cylendes, has a brand new proportioning valve. Car is ready to go. needs to be used more has not left my property in over 2 years due to my dirt rd. I have the stock intake, exhaust manifolds, hood, ralley wheels with tires, caps and rings. I have many more stock parts that all are included as part of the sale. This car must be seen it's not a clone as almost all are any more. Car can be driven as a cruzer and will surely not disappoint you if someone at a local cruise night is mouth running. It's dependable and runs awesome. No surprises no leaks and Very FAST!!! Serious calls only please. 28,500.00 810 701 8766 More pics upon request. Durand Michigan [email protected]
