plz help identify this
gniknayrb18
san angelo, tx
a holley carb not sure what the size is cant find any numbers on it
prolly 600 and has ford kick down.it's not a bad carb as long as it runs good.a mild small block likes a 650 double pumper though...
The list number should be on the front of the choke tower. It looks like an OEM older Mustang carburetor. If so, it's a 450 vacuum secondary. Would be perfect for a slantif that's what it is. Two giveaways. One is the Ford kickdown linkage as already mentioned. The other is the anti run on valve bracket just ahead of the linkage. The 450 Mustang carburetor had both.
Probably about 50 bucks.
so next question is how much is it worth used
You need a list number to know what it's worth.
We had one thread like this.... The list number showed the carb was for a 1970 Chevelle LS6. The used value on that carb was $900. $900 is more than the guy paid for the car it was on.
Find the list number.
X2. Take the black ringy thingy dingy off and look on the front of the choke housing.
